CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Mon Mar 29, 2004 12:37 pm
Quote » Once again, a GSR 1.8 is no CA18DE or DET. Totally different platform and is a tad bigger and uses a mechanical/electrical additive (or VTEC) to increase power in the upper rpm range. That dyno seems biased and I really don't think that the power differences between the two is that great. And which T3/T4 are we referring to here? [/quote]the turbo spooled way before teh v-tec even kicked in on this dyno, unfortunately i dont know what t3/t4 it was. sure it was T3/to4b 57 trim,.. .63 blah blah blah,,,
anyway it shows it on a 1.8 motor... with similar AF of 36lb/m
(and the SR is 40lb/m so it isnt that much of a difference in performance between the SR and CA ~40hp at MAX so SR's making 360whp w/ GT25R, Ca's should theriotically make 320whp at the smae boost)
also
how could you really reccomend the .48 or even the puny little .36, thats a terrible miss-match for the T04E compressor and will hurt any sort of flow that compressor may have.. the .48 will not flow enough exhaust gasses to reach any sort of effieciency zone, i think 12-14psi will be the max, where the T04E compressor with a 1.8 motor will be in wonderland around 20+psi boost (76-78% efficiency on the compressor map AF=36 and PR=2.4)
Quote »I am convinced that the GT series turbos are efficient enough for the CA18DET, but I think the issue here is the cost-effectiveness of these units in such a budget-minded community. I was offered sponsorship on a GT3037, but at the same time was swayed by my turbo builder with the fact that if and when it broke, I would be forced to pay for a new one out of pocket.[/quote]cost: huh?
T3/T04E - $600-$800Wastegate - $250+T3 custom Manifold - $500-$800custom 02 pipe & custom Down pipe - $200-300Flanges & Gaskets - $150Oil lines & Fittings - $100install - ???
bolt on solutions - GT28RS - $800 - (suggested HKS actuator)GT25R - $1024 - (suggested HKS actuator)
and GT series turbos dont just blow up, and most of them as being new, come with a waranty... the only one i have heard of letting go was movingviolations when his manifold broke and piece toasted his turbo, this is not the turbos fault,,, and would have lived for years like any other turbo.
T3/T4 hybrids are technology of the 70's, old things, desil truck turbos, time to step up to the future, and the GT series is the future of turbo technology, the new GT25R, GT30R, GT35R, GT40R and GT45R are taking over the compact world, and time will tell. i know i am right on this otherwise GARRETT and HKS would not be spending all this time and money developing the GT series for comapct cars..
Quote »(To r34) It's too small to warrant the price. Get a t28 and be happy.[/quote]I would reccomend the GT25R again for the same reason i ahd in the past, easy bolt on, allot of people are using them now with fantastic results. but if price is your thing the S15 T28 is a great option and proven quick spooler, good for about 280-300hp. but they are a bit expensive these days,
i think i have exhausted myself trying to keep up with this post, you are on your own buddy, i have posted the info, others have contested it, some have supported, you make the decision, but i am sure you'll be happy with either turbo series..
Quote » Boost_boy wrote:So what you're trying to tell me is that on a stock CA18 and GT25 series or A BIG T28 turbo, these guys are going to see 300hp? It is not just the turbo that makes these engines go, they just support it. And I guarantee you that any of those T2 small turbos on the CA18 will be straining to get anywhere near 300hp and I'm talking at the crank. Never said 300 was impossible, but who in the hell wants to be straining there precious and expensive GT turbo just to say "I got 300hp"![/quote]Quote »boost_boy wrote:Even I would accept this. I had a SR T25 done for one of our board member's CA motorset he purchased from me, but I had it twisted a bit. It now sports T3 blades and he got a fresh cartridge all for under $500 and I'm pretty sure that he should be able to see very close if not over 300whp. I used to use a similar turbo which allowed me to whack a WRX, smoke an audiTT, S2000 and a turbocharged IS300 on the highway at over 160mph. And even thought the turbo got killed shortly after, it was very cheap to rebuild, but I sold it to a guy with an SR20 in Tampa. Those sneaky little hybrids work just fine for the low-budget booster. It just that it's not wise to be sustaining 15-18psi on the highway for nearly an hours time. I enjoyed killing it .
[/quote]so can T25's make 300hp or not....
hmmmmmmmmmm......
