turbo timer
mean green s14
Car: driving like a retard
can anybody tell me how to hook up my hks type 0 turbo timer to my 97 240, i cant find a harness and dont know what wires go where please help!!!
huguetpj
Car: 93 KAT Coupe
Do you know what the wires on the turbo timer are? Meaning do you have the instructions for the turbo timer? An FSM would be good, and I don't know if the 93 and 97 ignition config is the same but maybe this can help:
http://katcostarica.240sxonlin...r.htm
Even better, use a tester to find out what each wire on the ignition is. You have to find out the following signals:
ACC - 12V when key at ACC & ON. 0V at STARTON - 12V when key at ON & START12V - always 12V (connected directly to the battery)
Then just solder the turbo timer wires to the correct ignition solder point.
Hope this helps
mean green s14
yes very much so thanks alot
