KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Wed Jan 14, 2009 5:53 pm
so, my turbo has takin a ****, its smoking badly, but even more so once i T'd in the exhaust side crank vent, into the intake side crank vent that goes to the PCV valve.
I was wondering about how much oil psi should an oil cooled only turbo be running? and if i should be using a restrictor with this turbo(garrett 50trim t04b), and if so, what size restrictor?
also what kind of setups are you guys running for the valve cover venters, the one that goes to the turbo intake stock, was pushing mass amounts of oil which made me stick a breather filter on the line with a homedepot catch can for the mean time. it still pushed oil out of the filter, quite a bit too. so i t'd it into the other line that is on the intake side of the motor, whats some ideas to set this up? i feel like as soon as i t'd it in, it smoked even more.
Thansk, thoughts and ideas will be greatly appriciated.
oh, also, what is weird, is the turbo has a little shaft play, but not too much, i have ran turbos on other cars with more shaft play than this one, with no problems, so im pretty confused.
Modified by KEMP at 8:58 PM 1/14/2009
