Turbo oil feed and coolant lines, for relocated turbos?
TD or Not TD
Car: 1986 Corolla GTS
What do you guys run for oil feed and coolant lines when you relocate your turbo? and where to get it? my car is close to being running and im trying to gather everything up.
themadscientist
where are you "relocating" it to?
Masterdebater
Car: 1989 nissan 240sx coupe
screw the coolant lines just get a steel braided line for the feed and block off the water lines
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Im kinda curious about this as well.
Why would you not want to water cool your turbo? Really, wouldnt water cooling it help keep it cool? Please explain to the turbo-challenged (like myself).
And for relocating it, my turbo sits just a little different from stock due to the new tubular exhaust manifold. I have all the lines working with the exception of the oil return line. It is way too long and way too close to the block now. Does anyone sell a braided line that large for the oil return?
themadscientist
Heat the pipe, stick a 1/4" or 3/8" socket extension in it and bend it to aim correctly.
Masterdebater
most people out here just lose the coolant lines because its expensive to get both braided lines. unless ur boostin high then u would want it
themadscientist
If I had a turbo with the ability to water cool the cartridge I would take advantage of it.
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
themadscientist wrote:If I had a turbo with the ability to water cool the cartridge I would take advantage of it.
+1; less oil coaking and extended turbo life ftw. I take it that you are going to be running a top-mount setup as opposed to a stock-type bottom mount? You can easily piece together a kit with fittings/hose/lines from ATP (www.atpturbo.com) and Summit (www.summitracing.com)
TD or Not TD
Actually the turbo is relocated for the CA to fit in my corolla a little better. it sits lower and away from the motor more. and it also has an S14 turbo on it. im not worried about the coolant lines. mainly the oil line.
Sil40sK
'88 Porsche 911
'02 Ford Focus SVT
Well as far as the oil feed line is concerned, you can just use a taka motorsports one for an SR20 (with some different fitting for the block I think), I have that on my CA and it has more than enough line to reach the turbo, it actually goes to almost the end of the block the turns around to come back to the turbo.
TD or Not TD
awsome! thanks for the helpfull info!
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
Hello all.
I recently upgraded to a rebuilt Garrett T25G taken from an SR20DET, but I'm having issues with the oil feed line (long story but in the end it's leaking). I was thinking that takamotorsports "Oil In Line SR20DET T25 and T28" (item no. NISX5000T) would be the one one I need, but from what I've read around here I might need a fitting adapter to get the line working on the CA block. Is this true?
And is it humanly possible (or is there any special tool) to release the oil feed line without having to remove everything else?
Here is how the engine is looking after some minor upgrades. In the end all thanks to the Nicoclub forums as my n°1 info source. Too bad I can't use the car as it would leave small puddles of oil if I I turn it on.
Thanks in advance,
float_6969
If you email Taka and tell them you have a CA, they'll send the correct adapter with the line.
Cams
2013 Scion FR-S
2016 Infiniti QX50
I already have, but their inbox(es) keep(s) bouncing back.
t104racing
Car: 1987 Jeep Wranger turbocharged 4.6L stroker
steel braided line is the best way to good
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
Cams wrote:Hello all.
Thanks in advance,
out of topic question but because its in here....
lol whats going on with your FICD...looks like 2 butt connectors....
hows your catch can hookd up? looks like 2 cover nipples joined together to the can with an open end...what do you have blocked off at the back of mani
whats the black box near the resistor box
