turbo coolant return line
tyrannix
Car: go big or go home
the last thing i need to install my engine, the one that goes behind the block
anyone have an extra?
my stock one got bent between japan and here, finally it just broke, about 2 inches from the banjo fitting, im going to try and weld it back together
im going to replace with braided stainless later, but almost just to document it as doable, i want to use all stock lines on the gtir turbo. the coolant send is all set, got the bracket all welded up, just need this one thing then i can install the engine.
