DSSA »
https://forums.nicoclub.com/dssa-u8104.html
Sun Aug 24, 2003 6:45 pm
Do what you want, but you might want to look into what parameters Nissan put into the stock ECU as to how it reacts without any input from the 02 sensors. I have never gotten to see code, but if it's like a lot of other manufacturers, the ECU will not only dump fuel, but retard timing like crazy.
You're not reinventing the wheel by thinking it's a "good idea" to run a stock ECU car without 02 sensors, and tuning while the ECU is in "limp mode".
What you're trying to do is possible with a lot of standalones (although not always the best approach) however, manufacturers put a lot of effort into a code that the ECU switches to when it's in open loop to prevent the motor from toasting itself.
I say if this isn't a good enough reason, then go for it, it's your motor and money wasted, not mine. Let us know how you make out.
