Any one using super AFc2 running z32,ecu? I ran stock ecu with Z32, msd 50lb injectors for a while but car ran too rich,so i sent ecu off I have a tuned rom chip for 550cc and z32 come in ,but I have msd 50lb injectors (a litttle less cc) Z32 and super afc2, It runs horrible ! way to rich at idle on wideband 10.4, or way to lean or stupid rich trying to change the in and out numbers on super afc2. it ran good before change stock mafs, injectors,then i out Z32 mafs on and msd injectors ,It hasnt ran good since. I was going to fine tune the 50lb to the tuned ecu with wide band ,and cannot find correct numbers in and out . The book numbers in manuel would not work. it is frustrating.
any help on what numbers to use that you guys with SR20det tuned ecu for 550cc 's , aZ32 mafs and use super afc, I have msd 50lbs injectors and I don't know if that matters, please respond to help out if you know.
thanks mike
