DeviousNismo_240 »
https://forums.nicoclub.com/deviousnismo-240-u3753.html
Wed Jan 22, 2003 12:34 pm
I would get a throttle plate/induction cleaning service performed, then, after, and only after, go to the dealer and have them adjust the base idle. The cleaning service will bump up your idle, and you will need to have it adjusted. You need to unplug the TPS, to get to base idle, and depending on if you motor is an E, or DE, adjust the idle screw till the rps is @750 +/-50
