DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Wed Apr 12, 2017 6:15 pm
Hey Dave, long time no-see!
Hope the Z is still treating you well.
I haven't done this, but I'd look at one of the epoxy kits that you can get very reasonably at home supply stores in the paint department, adhesives... and probably use a plastic epoxy that also will stick to glass and the plastic mount clip, just check the list of items each product works with. I used a plastic version for my jspec repairs and the stuff is legit, still holding years later and after several removals and twisting, etc.
Epoxy is one of the strongest glues known, a permanent hard set glue that won't be affected by heat under 200 degrees in most cases. Many of the kits come with the self-mixing tips which are the best version- handy since you'll usually use very little each time and the further potential uses are huge. JB Weld is also pretty good for more heated/abused conditions such as under-hood, body, etc. and IIRC also has several types/grades.
