DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Mar 10, 2017 11:51 am
Be very, VERY sure about what you do from this point forward, your engine's life hangs in the balance.
You have an interference engine, which means that when/if the cams are out of time even more than ONE TOOTH, your valves collide with the pistons and the valves or even both are destroyed, permanently. You are feeling this when you can't turn the motor over past certain points, and I hope you didn't try forcing it.
DO download the fsm and DO use it for everything you do moving forward, being certain of each step. If this gets beyond you, and it may well (I myself would never try this job, and have done 99% of my own work) do find a certified, for-sure Nissan Z32 guy to do that job as it is by far THE most important item to be correct in a VG30DE or -DETT motor!
