Truck's Last Stand.. Help!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
ProteanCarnage
Car: 84 Nissan D720 2x4 2.4L
Alright guys, i truelly need some help now. Seems my truck is having quite a pickle of a problem. It's not starting. Its not getting spark from one of the coils. Yes just one. The one with the red, and the blue wires, never works. ive switched them around and always only the one with the brown tries to fire. Before you try to give me help, read this
THINGS IVE REPLACED
-New Battery
-New Alternator
-New Spark Plugs
-New Spark Wires
-Refurbished Distributor+icm
-New Rotor
-New Cap
-2 New Ignition Coils
-the condenser was switched with the relay by fuse box, no fix
Okay with that information, what the hell is going on with my truck -_-
http://asavage.dyndns.org/Nissan/displa ... age=20-032
this page may be of help, but i cant see anything that would break and not disable both.
the one with the brown wire ALWAYS fires, but the truck still wont start.
mattthruwalkin
Car: 1984 nissan 720 4x4
mine was doing that crazy stuff to , replaced both coils still had a miss , tested both coils both good just 1 when hooked up on truck it was not firing .... so i bridged the coils and it ran fine, take a heavy wire and attache to the neg and pos posts of the coils and put the rubber covers back on.... only a quick fix till u find the wiring problem and i have yet to find the problem on mine gl, let us know if u find a solution
Return to “Datsun 720”
