Troubles Starting
Ride240
I have a problem starting my car up in the mornning or when the car has be sitting for a good amount of time, like about 6 or more hours. The turns over but it takes a good deal of playing with the gas to actually get it going. If any of you guys can give me an idea of what this could be please tell me. I have new Python fuel injectors that work good and put in a new fuel filter bout a week ago.
Thanks
SPIRO
I have the same problem with my 89 SOHC. I changed my fuel filter, cleaned my K&N cone, checked for vaccum leaks, oil change, let the engine suck up a can of sea foam, changed o2 sensor, and got new NGK plugs. Nothing helped. You'll probably get more help with problems like this if you post these kinds of questions in the online mechanic section, but if anyone out there can give us any advice as to what might be the problem itd be great.
