I am having problems with the yellow box speedo calibration to correct my speedo for the 4.08 rearend.
I have it wired up and it works fine until I get over 25+mph and then it goes dead....well the speedo stops working and just says "zero". As soon as I slow down under 25mph the speedo works again. I have run all the tests and everything appears to be operating correctly except for the test that you can set the box to output a constant signal while in park to test the output function and it is suppose to register something between 5~100mph when I do this test as the pulse register differently between cars.
When I swap out the little calibration box for the bypass wire that totally bypasses the box and just makes a continuous loop the speedo works fine all the way up...100+mph although the speedo is not correct.
I would think that if I had a loose/bad connection that when I install the bypass wire that my speedo would not work, but it works fine. Does anybody know why the speedo would work till 25mph and then all of a sudden go dead?
Wes has a video clip that I am waiting to be hosted so I can link you all to it so you can see for yourself what it going on.
Here is a link to the box.....
http://www.blackrobotics.com/yb_home.htm
EDITED: Here's the link..
http://www.q45.org/rob/speedo.asf
