:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Nov 05, 2003 10:10 am
A/R is basically the housing size - Bigger # = more flow.
Trim is the size of the wheel - Bigger # = more flow.
So you match the trim based on comressor maps and your desired HP/boost level.
The A/R can be changed to affect spool...but for a KA, .63 is pretty good. But turbine wheel stage (stage III, stage V) affects this as well...i.e. a .63 A/R with a stage V wheel will spool slower but have better top end than a stage III of the same A/R.
And for my unrequested but relevant turbo reccomendation:
T3/T04E, 50-trim compressor, .63 A/R - Stage III wheel
Perfect for a KA.
Or even better, one of the new Garrett GT turbos that approximate/replace the T04E 50-trim.
Later - Brian
