originalsin »
https://forums.nicoclub.com/originalsin-u14941.html
Fri Jun 24, 2005 3:48 pm
ok so i hooked everything up and tried to turn it start it today, crank over fine, tried it twice for like 5-10secs each and got nothing, 3rd time it seemed to fire a few times but never actually started. i dont have ic stuff hooked up or vac lines, but it should still atleast start and die right?? and when im cranking it the check engine light is off but wen i stop it goes on and the red and green lights on the ecu are on (idk if that means anything) but yea it was dark to then i just cleaned up. so trouble shooting... obvioulsy check for spark (plugs are alrdy new and gapped) i am almost positive im getting fuel because i thought i might have had the lines reveresed and when i pulled um off i got a good blast so yea i reversed tho and wasent even starting to fire, so they must have been on right (the feed line is the top one right? like that should be hooked up to the fuel filter) any other suggestions?? i dont expect it to run or anything, just start and prolly stall out, because its much easier working on everything with more room
