Q45Viper »
https://forums.nicoclub.com/q45viper-u6953.html
Mon Mar 31, 2003 6:05 pm
Well, I started an entire thread about this a month or so ago and I did not get any transmission comments at all, maybe because I mentioned that it was a 92 Q on it's second trans with all the updates done. The comments I got at that time were all about injectors, maf, knock and o2 sensors. Now I hear it may be the transmission? And the way it's being described at 40-45 mph sounds exactly the same as mine. It's going in again in a week to have this completely looked at. Some of you are saying it's just normal and live with it? Two threads, one ends up with an analysis of injection, and engine controls issues, this one suggests the transmission. What is the best guess for this shudder? Feels like a temporary miss while going through 40-45mph on gentle acceleration. One more time please. Especially as mine STARTED behaving like this a month or two after the last flush. I'm at 130k and almost everything has been upgraded including throttle body clean, injector clean but the plenum has not been removed, cleaned and the hoses underneath have not been changed out, or have the injectors. The disturbing part of this thread is that I was prepared at this point to tell them to pull the plenum, clean everything and replace EVERY hose they can find, and maybe do all the injectors. Now I'm not so sure. It might still be the transmission? Can any expert here help me determine which way to go here? Cause you know the dealer will be happy to go both ways at twice the cost!
