qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Wed May 09, 2007 10:49 pm
No, that is the check engine light. You can check what the code is with a consult cable/laptop, a real consult (mostly the dealers have them), or you can drop down the ECU in the passenger kick panel and on the back of it (opposite the harness connector) there is a red LED and a potentiometer. Turn the pot clockwise about 1/2 turn til it stops, wait 2-3 seconds, then turn it back til it stops. It will flash a sequence which indicates what the code of.
