Pat S »
https://forums.nicoclub.com/pat-s-u4002.html
Tue Oct 21, 2003 5:12 pm
Transmission just replaced, it works fine. Wife is driving car ('91Q), hits bump and engine kills. She is able to restart car but has problems with it stumbling.
I suspect fuel pump going out (pump has been noisy). I replace pump w/new OEM pump from Scottsdale. Still having problems w/stumbling. Car will start and idle. put it in drive and it will sometimes kill. Keep one foot on gas and one on brake to keep rpms up and it will not kill. Once you get moving it does ok, not great, will stumble sometimes and then you can nurse the gas pedal a little and it will clear up. You can go to WOT and it pulls real well w/only a slight hesitation, then it clears up and runs fine to redline, pulling hard all the way.
SO, what is the problem? Pump controller? Loose connection as a result of transmission replacement? Fuel filter? Fuel pressure regulator? Vaccuum leak?
If the pump controller is bad, does the pump not work at all. Is it possible for it to work on only two speeds and not on the other one (Example: Low and high speeds work, but not middle speed)?
:help
Pat
