That does seem a bit odd. If there is no dipstick at all, to measure your ATF level, you can always measure the full amount of old fluid you drain out and then refill with an equal amount of fresh ATF. As long as you do not have a transmission fluid leak going on, whereby the current level is bound to be low, this drain and refill measure method works well enough to get the fluid level correct.NorwegianPathfinder wrote: ↑Sat Feb 26, 2022 1:18 pmApparently they decided for this model to not install the pipe, ... I haven't started the procedure yet, so I'm not sure whether there be a short dipstick going down from the aforementioned lid, but I'll soon find out.
Just so that I'm clear; Since you mentioned transmission dipstick to begin with, I assumed you have an automatic transmission. Is that right? I just realized that model of 2010 diesel is available with a manual transmission as well. There's a different fluid fill and level check for a MT, which is much the same as the transfer case.mdmellott wrote: ↑Sat Feb 26, 2022 2:06 pmThat does seem a bit odd. If there is no dipstick at all, to measure your ATF level, you can always measure the full amount of old fluid you drain out and then refill with an equal amount of fresh ATF. As long as you do not have a transmission fluid leak going on, whereby the current level is bound to be low, this drain and refill measure method works well enough to get the fluid level correct.NorwegianPathfinder wrote: ↑Sat Feb 26, 2022 1:18 pmApparently they decided for this model to not install the pipe, ... I haven't started the procedure yet, so I'm not sure whether there be a short dipstick going down from the aforementioned lid, but I'll soon find out.
Any A/T (even a CVT) can be safely warmed up in the garage by doing a low-grade "torque converter stall" with foot on the brake and transmission in drive with the RPM held at 1200~1500. This causes the converter to heat the fluid from hydraulic resistance without actually moving anything but the turbine shaft, which is why it's safe even for CVT belts. Just don't get carried away, about 3 minutes at 1200 will suffice on most vehicles.mdmellott wrote: ↑Mon Feb 28, 2022 9:55 amWarming up the transmission by driving 10min or so is necessary to get an accurate measurement on the dipstick but some dipsticks have a hot and a cold fluid level line so in those cases it's not necessary to warm it up. Running the engine while parked does nothing to warm up the transmission.
Excellent tip! I will be doing this next time and always afterward. It's safe assume this is also a good way to meet the precondition step of warming up the transmission before doing the idle air volume relearn procedure. I like this! Thank you.VStar650CL wrote: ↑Mon Feb 28, 2022 10:53 amAny A/T (even a CVT) can be safely warmed up in the garage by doing a low-grade "torque converter stall" with foot on the brake and transmission in drive with the RPM held at 1200~1500.
