VStar650CL wrote: ↑Sun Jun 12, 2022 12:04 pm
I have a Hayden 512 6-pass on our Altima and it's pretty much overkill for the job, good quality unit and easy to tack on. I'd think it would work fine for your Pathy. Guys disconnect the original heat exchanger in the radiator because they're afraid of the exchanger failing and mixing coolant and transmission fluid. That was really only a big issue on early~mid R51's, but some mechanics hear "Pathfinder" and do a bypass like a knee-jerk. If you want to leave the OE exchanger disconnected, there's nothing wrong with a radiating cooler like the Hayden. Same job, different mechanism.
Thanks for recommendation!
And would I hook this up the same way the original one was? In terms of the hoses routing back the original way? Not too familiar with this so I may be misunderstanding.
There are still two transmission hoses going to the bottom of the radiator. One of them is supposed to be coming from the separate transmission cooler but has since been coming straight from the transmission pipe since the cooler was disconnected. Haven’t had any mixing problems. Radiator was changed once.
I’d have to figure out which is the return line and which line sends the fluid.
