Transmission/clutch Issues
Nissan 350z / Nissan 370z general community discussion forum
pc1212
I have had this issue for the past 4 months now. I already posted on the Nissan Mechanic side of the Forum and they told me to take it to the dealership. Well I have been in and out of the dealership 3 times and I have yet to duplicate it on the spot. Can you all just give me an idea of what I am dealing with so I can have some ideas when I go back into the dealership?
-The transmission makes a clanking noise when I shift from 1st to 2nd (6mt).-Second, my clutch pedal will become mushy and get stuck for a bit and then go back to normal. I figured it was the warm weather/humidity but it did it yesterday when it was 68 degrees.
yelohandL
Car: 350Z 2008
you should read FAQ before somebody flame on you.
that's normal for Z. it makes alot of transmission noise
because it's like bolt-something transmission.
idk about the mushy clutch but... if you really wanna get
rid of the clanking noise i heard you can get it lubricated
but i think all Z owners just live with that.
pc1212
I appreciate the timely response, but I am not a noob and know when something is wrong. I understand the transmission in the Z is noisy but it should not be making a clanking noise when shifting gears. Loud whining noises coming from the transmission is normal for the Z, but not a clanking noise. In addition, the clutch should not get stuck unless their is a underlining condition causing the clutch to not function correctly.
R350Zz33
Car: 2008 350z enthusiast
bad syncros ?
pm_page6776
Car: 2009 A/C 2.5S
Clutch pedal intermittently going to the floor and can be pumped back up. Sounds like your clutch master cylinder is failing. If it is not completely releasing the clutch when pressed, it can cause a girnding/clanking noise when shifting.
Burtonboarder950
Car: 2005 350z touring
i get a clanking noise that sends a tiny shake through the car every minute or so when in neutral. Is that normal too? Sorry to change the topic but its similar. Thanks in advance
Watermelonwarrior
Car: 2006 Cayman S 6SPD
Burtonboarder950 wrote:i get a clanking noise that sends a tiny shake through the car every minute or so when in neutral. Is that normal too? Sorry to change the topic but its similar. Thanks in advance
I have the same problem. My warranty is about to expire and I want to try to get the transmission swapped before it does
Burtonboarder950
do you think its the transmission that is clunking. Im afraid its a misfire or something, but my guess is as good as yours. And if it is the transmission do you think its so bad as to have to replace it?
Watermelonwarrior
its definitely the transmission. Im not sure if its serious. I just don't want something serious to pop us jan 1st and i have to pay for the whole thing.
Burtonboarder950
ok i know what you mean, if i still had the warranty i would do the same in ur shoes, just to stay safe. But thanks for letting me know its the transmission and a lot of u guys hear it. Like some1 said before, there is nothing better than finding out what you thought was wrong with your car isn't anything to worry about. Thanks a lot bro
Return to “350z / 370z Discussion”
