The only bellhousing bolts that I was able to reuse from my swap was the ones where the gussets bolt to the tranny, the auto starter bolts will not work with the manual, here's the info that I used from
http://www.ka24development.com, the sizes listed work just the same for the sohc and the dohc. I had a hard time getting all of the bolts at one ace hardware, I ended up going to three different places to get all the ones I needed, just be sure to get grade 8.......
The bellhousing bolts are similar, but different for the Auto and 5-speed transmissions...you may be able to reuse a couple, but you'll need new ones (length) for 95% of the bolts - Anyway, here are the part numbers and lengths:
Bolts = 08131-0601A / 60mm length / 4 neededWashers = 08915-2401A / 4 needed
Bolt = 08131-0701A / 70mm length / 1 neededWasher = 08915-2401A
Bolts = 08124-0301F / 35mm / 2 neededNuts = 08911-2401A / 2 needed
Bolt = 08124-0601F / 65mm / 1 neededNut = 09811-2401A / 1 needed
Bolt = 08071-0251A / 25mm / 1 needed
Starter Bolts = 01121-03751 / 95mm / 2 needed
Credit to "roycenagger" from Freshalloy for the part numbers listed here...
If you choose to get these from your local ACE Hardware (or wherever)...the bolts for the block are all M10 X 1.5 thread/pitch, so just find bolts of the correct length as listed above.
