Soliyou »
https://forums.nicoclub.com/soliyou-u303319.html
Sat Apr 30, 2022 2:10 am
Hello everyone.
I have 2001 qx4 with all-mode transfer case and around 189k miles. I bought the qx4 around six months ago and I think the transfer case fluid was never changed.
The issue: when I select 4x4 via the switch, it is supposed to lock the into 4x4. In my other 4wd trucks, if you make a turn with 4wd locked on dirt roads, the wheels would hop. However, in this qx4, when turning, the transfer case clutches slip and I can feel the screeching in the drivetrain, no wheel hop at all! I changed the transfer case fluid 3 times, but it is still pretty dark.
The question: is it normal for this transfer case to allow slip when turning? Or clutches are gone? I am worried it would also slip in a straight line in a high demand situation.
