Transaxle broke off flush with transmission
A forum for the Nissan Quest... minivan lovers unite!
Patagriff253
Car: 2004 Nissan Quest SE 3.5L
My driver's side transaxle broke off flush with the transmission. How do I get the broken part out of the transmission?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I presume you mean the splined portion of the inner CV joint. Transaxle is a term for a FWD transmission, your transmission is one. The only way I know about to remove that is to drill and tap it, then thread a small slide puller into the tapped hole to yank the broken portion clear of the C-ring that holds it into the transmission.
Return to “Quest Forum”
