transmission filter change
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
rdjette
Car: 2009 versa
I have change transmission filter on many cars. on the 2009 versa is it like most others drop the transmission pan and filter right there, or do you have to pull the transmission to change the filter
alonsorules8.1
Car: 2008 Nissan Versa SL
2010 Nissan Versa S
It is like most every other model, unbolt the pan and replace filter. I would also recommend doing a complete transmission flush afterwards so that the cooler and lines get new fluid and you don't run the old fluid and new fluid together which can lead to slipping.
rdjette
Car: 2009 versa
Thank I was hopping it was drop pan and filter just looking at you. how do I do a complete fluid change I understand it is like 8 or 14 quarts
alonsorules8.1
2010 Nissan Versa S
there is a machine at the local auto repair shops use to flush the trans fluid including your dealer. Sorry I didn't ask this earlier but is your transmission and auto, or CVT? If CVT it requires special fluid and runs $20 a quart at the dealer.
Return to “Versa Technical Discussions”
