Traction Control
allsfine
Car: 2007 G35S Sedan
Hi.I have a '07 G35 S Sedan and when the traction control switch is engaged, and you attempt to test the limits, another "Traction Control" function takes over & prevents any tire spin. Is there a way to override this "nanny controller"?
JeromeS13
Car: 2008 Subaru Impreza STI
Yes, use the switch to turn off VDC.
-Jerome
allsfine
I have useed the switch. On my '03 G35 this was effective.The '07 it does not really work.
allsfine
Hi Jerome.I engaged the VDC switch, but unlike my '03 G35 Sedan which worked great, this switch barely has any effect. Do you have any other idea's or know of someone that I can ask anywhere?Appreciate your assistance.
Q45tech
Download your 2007 FSM and study schematics.
Manufacturers are getting better and better and protecting themselves from damages caused by owners illegally modifying.
You can usually create a fault but with integrated ABS/Traction/dynamic handling you may end up shutting down all 3 and having ecu decrease power to protect you.
There is a bill in Congress to make dynamic control mandatory just like air bags.
