VDC, voltage, direct current93 Z32 wrote:What does 'VDC' mean?
Lowering the TPS voltage will lower the idle speed, and make those shifts happen earlier and more smoothly. Go too far and the transmission will "hunt" between 3rd gear and OD, when pressure on the gas pedal is light. Idle speed can be increased by adjusting the idle screw on the side of the IACV.93 Z32 wrote:I actually had to do the wd40 lube on the iacv. Then I adjusted my idle down. It was idling up around 1050-1100 rpm. But I adjusted the TPS to .45 before I adjusted the idle down. Now when I start it(cold start), it goes up to about 1300rpm for a couple seconds, then drops down to 800-850. Then put it in drive, goes down to about 650rpm like u said. But it just wants to whine the gear out then shift, and shift kinda hard. So I should probably lower the TPS voltage huh?
I tried, very unsuccessfully, to adjust mine by feel and focusing primarily on idle speed, without using a meter to measure the output voltage. Another thing to watch closely is engine rpm speed at highway/cruising speeds when in OD, as it really effects gas mileage. My J30 runs about 2,800 rpms at 70 mph.93 Z32 wrote:So I need to lower the voltage on the TPS. Which will lower my idle speed. So then I need to adjust the iacv back up a lil to compensate for the voltage drop.
So I need to find that sweet spot. I did notice that when I raised the voltage from the .32 it was set at, the throttle is more responsive. But shift points are bad. Ill drop it down to about .35 and adjust up from there. Thank god I live out in the sticks in southern Louisiana so I can get on the road and test it easily lol.
A couple of new O2 sensors improved my fuel mileage. I also replaced PCV valves and made sure that the IACV, AAC and Air Regulator were working properly and clean. I also unclogged the EGR tubes, when I pulled the plenum.93 Z32 wrote:So this would explain my poor fuel mileage too then?
Car is maintained very well. New injectors. Plenum/fuel rail insulators. Plugs. Coil packs. Fuel pressure regulator. Fuel filter. TPS. PTU. PTU sub harness. New vacuum lines. Pcv hoses. Order all parts thru Z1.
Glad to read that things are improving, and thank you so much for the updates and the thank you.93 Z32 wrote:Set mine at .39. Took it for about a 20 minute drive, fuel needle didn't even move. Shifts beautifully. I had my voltmeter on the wrong setting. So it was set in the .5s. Way to high. I greatly appreciate ur help and knowledge.
It's been a few years since I did mine. It's important to have the proper O2 sensor socket, breaker-bar and open-end wrenches, and it probably helps to apply some penetrating oil first, giving it ample time to work its' way in. The O2 sensor on the J30 passenger side threads into a threaded reducer bushing that came out along with the sensor. Separating the two galled the inside threads of the reducer bushing, but I was able to use the other old/good O2 sensor, along with some lubricant, to chase and clean them up. No project ever goes as smoothly as it should.93 Z32 wrote:How hard it is to change out the O2 sensors? I'm gonna order them tomorrow. My buddy has a lift at his office. So it won't be that hard to get underneath the car. I have Megan racing type2 catback system and down pipes. Will I need to remove the downpipes to access them? I have a whole nother complete set of gaskets for the flanges for the exhaust. So that's not an issue.
