SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Sat Sep 27, 2008 1:27 pm
The light will come on and stay on if the sensors have been registered. That is a process we do at the dealer using the Consult II (or III) and transmitter to get the BCM (body control module) to recognize the sensors. If you remove your sensors, you can try to have a technician perform only half of the registration process but I am not sure if it will keep the light from comming on or not. At the beginning of the registration process, the origional codes stored in the BCM are erased and all slots available to recieve information from the sensors read "YET" meaning they haven't been programmed yet. At that point, instead of programming the sensors, have the tech select "BACK" on the Consult II to exit the programming proceedure. Again, this may or may not work, but I think it will.
I will say though, that it is a great safety feature to have those sensors installed and it should fit 95% of the wheels out there. It's best to keep them installed, especially on long road trips.
Hope that helps.
