I was searching the forum for this but can't find anything. Is there a way to DIY re-program the Rogue or at least reset it? I bought 4 winter tires with alloy rims off CL with installed TPMS. The receipt is included on my purchase from the owner and it clearly says TPMS sensors installed on them.
After installing the tires some weeks ago. The alert on the dashboard didn't flash for about 3 days. Then one day it showed up on the dash. I checked the inflation and it was spot on at 33 psi. All of them the same. I'm guessing right now that it actually needs to be re-programmed or reset. Or... the TPMS sensor(s) is faulty.
