Tpms flashing, c1708,9,10
Dosmastr
Car: 2011 Nissan Rogue SV
Good morning All,
I've had a time trying to get my code reader to pull the reason that my TPMS light flashes for a minute after starting the car and then goez steady.
Today I finally thought to drive the car first and then shut it off and then pull the codes, worked.
I find a little suspect that three out of four of my sensors would have all failed at the same time though
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Everything but the C1710 shows as "historical", which on most aftermarket scanners means "past". So the only one that's currently unresponsive is your righthand rear. The past codes may mean that all your sensor batteries are getting low, but the codes indicate 3 of 4 are presently working, not 3 of 4 failed.
Dosmastr
Derp...
Thank you
okay so safe bet is when I get the tires done have them replace all 4 batts.
Nice when it's easy
VStar650CL
Technical Expert
If the sensors are OE then you'll need to replace the sensors. The batteries are embedded and not serviceable.
Return to “Rogue Forum”
