Towing Info?
gebenhoeh
Car: Nissan Rogue
Plan to purchase in Sept. for annual fishing trip to MN. Will have AWD, Prem. package with tow option. My boat is alum. and 800lbs. Any info appreciated. Max. tow weight? Anyones experience regarding the 4 cylhaving enough power? Best to all!
exeunt
Car: 2008 Nissan Rogue SL AWD Phantom Pearl
Check the specs for the Rogue. Indicates that max 1000lb towing capacity, 1500lb with trailer brakes.
gebenhoeh
Car: Nissan Rogue
Thanks for the info. I had a Subaru Outback with a manual trans. and 4cyl and had no problem towing the boat. Hope the auto trans will do the trick?Once you get the load going it the forward load is almost nothing.
Return to “Rogue Forum”
