motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Tue Apr 22, 2008 3:03 pm
The lawyers got ahold of the manual and made a last minute revision to the tow rating. In my manual to font is even different.
1000lbs is no problem. The trailer hitches require a little drilling.
I'd would prefer the CVT to the standard automatic for towing because the lowest range on the CVT is much lower than the auto, so the torque converter won't have to work as hard.
I have the 6 speed manual, whci his ideal for heavier load with it's close gear spacing, relatively short final drie and very low 1st gear. The abuse on the clutch is minimal.
