ObsessiveDad »
https://forums.nicoclub.com/obsessivedad-u306865.html
Tue Jul 08, 2025 8:33 am
Recently replaced motor and tx mounts in my wifes 2015 SL, and had just replaced LCA's prior to that. The torque steer was pretty bad with the bad mounts, but it's still there now after replacement, although not as bad. It's most noticeable on the highway, when punching it from cruising speed to pass or going up a hill, it noticably pulls the car to the left, then to the right when the engine settles back down.
I can't find anything obvious, the CV's seem fine (replaced less than 2 years ago), no indication of a sticking/stuck caliper.
The mounts were likely bad for quite a while, is there something else that could have been damaged/separated that might cause this?
