imnprsd »
https://forums.nicoclub.com/imnprsd-u304061.html
Sun Jan 09, 2022 3:02 pm
Here's the DIY owner's approach I decided to follow when re-filling the ATF to the proper level on the Infiniti FX dipstick.
* First you need to know what the dipstick fill tube feels like "to the touch" when you reach normal operating temperature (~169F as shown on the charts above).
* To know what I'm taking about, just drive around as normal, for as long as you like, and then touch your dipstick tube.
At this point, your engine water temp will be ~182F to 185F, depending on the OAT, and your transmission fluid temperature will be ~169F. ...and the dipstick tube will be quite hot to the touch. ...And now you know what normal operating temperature feels like! However, I also need to point out, this is NOT the temperature you want to use when measuring your ATF level on the dipstick.
...But please, feel free to check you dipstick at this normal operating temperature so you know how much higher you will find it registering on the stick. Just know, that level could reach into the "first bend" on the stick and maybe higher, which is telling you this is an unreliable region to measure your ATF level. I.e., Infiniti dipsticks are read differently than any other car I have every owned. So don't assume your transmission fluid level should register within the hash marks at normal operating temperatures! (Tell your mechanic too, because they will probably make this mistake!)
* So don't be fooled! Read this post thoroughly and get familiar with the right way to fill your transmission fluid; and the right way to read your dipstick. ...One more thing, your mechanic will probably not want to take the time to use a scan tool. So you may need to convince him to do so. So, that's just one more reason to DIY if you ask me. Plus the entire process I have outlined is easy and think much better than using a traditional transmission ATF exchange pump!
* Don't want to get under your car? ...No problem. But buy a 12V, $18, transfer pump on Amazon to remove the first 4 qts of fluid out of your transmission pan; and then you only need to remove the bottom engine skid cover to reach your transmission cooler lines located next to your radiator to expel your old ATF fluid inside the torque converter, etc. (EASY PEASY!)
12V Transfer pump: Amazon.com: HYDDNice 12V 60W Oil Change Pump Extractor Oil Change Pump Transfer Pump Diesel Fluid Pump Extractor Scavenge Suction Pump for Truck Rv Boat ATV : Automotive
* FYI, I found the difference between the low-hash mark point on the dipsick vs. the high-hash mark on the dipstick is only ~3/8 qts, and this is when the fluid temperature is in the low-warm range (or about 122F).
HOW THE AVERAGE DYI OWNER CAN READ A DIPSTICK WITHOUT A SCAN TOOL
1) In the morning, when the fluid is cold... start the engine as usual. Let the engine run for 1 minute or so, as normal, and then drive the car for 1-3 city blocks, as normal, and shift through the gears.
2) Find a flat spot on the street or gas station to pull over and then do these things:
* Put put your hand on the dipstick tube (rear passenger side of the engine on my FX45) and note how warm it feels. When it feels warm to the touch, this will indicate your ATF is ~122F. (See charts above for where your ATF should register on the dipstick. ...It should be between the 2 lower notches at this point.
==> Now add 3/8 quart more of ATF and let the engine warm up more.
3) Now drive 5-7 blocks normally. Pull over and touch the dipstick tube again. This time it should feel much warmer, but not too hot to touch. ...This is the 149F point, and as you can see by the charts, your fluid level should rise and will register at the mid or higher-end region within the hash marks.
With the engine running, you will likely spend 5 minutes checking the dipstick several times, and at this point your ATF will continue to heat up, but not that much. When you feel the tube getting a hotter, but not too hot to hold on to, this is the ~149F point.
...And now you want to add ATF (1/8 qt of ATF at a time) ...but only to the top of the hash marks and no higher! ...And you are done!
Note: Your transmission dipstick is extremely sensitive. ...And each time you check the dipstick you should first shift through the gears while pausing for 3 seconds between shifts. ...Then wait 1 minute before you check the fluid level on the stick.
REMEMBER: Reading the dipstick at normal operating temperature (169F+) is not very accurate.
Tip: Use a file to etch a shinny mark on your dipstick to help you see the level and catch fluid.
