Code P0420
Forum for the unique Murano, and official home of Nissan Murano Club!
jsando2
Car: 1993 Nissan 240SX Hatchback
2009 Nissan Murano SL
Okay! I replaced all my (4) upstream downstream 02 sensors, both catalysts converters, spark plugs, three coil packs all the exhaust is new and Im still getting Code P0420. Also Im getting the code for the fuel sensor but here is where my question comes into place. Can a code for the fuel sensor trigger a P0420 Code? Hummm, What else can I do to get rid of this code I wont pass emissions and Im late.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Dunno what you mean by a "fuel sensor" code. If you mean the A/F sensor, then yes, a faulty one can cause a false cat efficiency code. Other possible causes are an exhaust leak, plenum gasket leak, or a replacement cat that isn't as efficient as the original. The latter is common with cheap replacement cats, and most people end up putting a spacer on the rear O2 to kill the code.
jsando2
Yes the A/F my bad, I just took it to a muffler shop to check for any leak and is all good, I guess is the cheap cats, I will try to place a a spacer on the rear O2 and see if that works! Do you know a good website to get it?
Thanks
VStar650CL
Technical Expert
There are tons of them on both eBay and Amazon for as little as $3, both straight and angled. It's not the sort of product where quality or materials matter much, but to avoid future issues put some anti-seize on it just like you would with a new sensor. Put "O2 spacer" in the search bar and you'll get thousands of hits.
jsando2
Yup just got a couple on Ebay. I hope it resolves the issue I have spent more than 2,000 on all this engine light P0420 and the shop i took it they messed me up with poor quality of workmanship horrible!
VStar650CL
Technical Expert
The spacers usually work well for killing the MIL from weak cats, but keep in mind that they're also disabling your "early warning system" down the road whenever the replacement cats wear out. That should be a long time, but if the car lives that long, it's something to be aware of.
jsando2
Yeah! Got ya! I will just put the ones for Bank one which is the one that's giving me that faulty code. I'll make sure I check them Cats once i start hearing or feeling the car all weirded up! I'll come back once i put them on for an update, Thanks!
VStar650CL
Technical Expert
It shouldn't be "them", you should only space the rear HO2. Spacers won't work well upstream, especially on cars (like almost all Nissans) with A/F's instead of HO2's on the upstream side. The ECM needs the A/F's to work right. We have a saying that "upstream sensors are for the engine, downstream sensors are for the government." That's because the only real job of a downstream sensor is emissions, monitoring the health of the cat. On the other hand, the A/F's are used directly by the ECM to regulate fuel mixture. So if your O2 is messed up, space it, but if your A/F is messed up, fix it.
jsando2
Thanks but that’s the thing right now I don’t know which one is messed up so I will put the spacer on the downstream and if it still giving me the code then I will know for sure is the upstream
VStar650CL
Technical Expert
jsando2 wrote:
Mon Oct 18, 2021 5:08 am
That's the right plan. :cool:
jsando2
Well today I got the P0420 on bank 2 as well something new it never happened before just bank 1. Well I hope those extenders fix the issue otherwise I will have to buy those A/F expensive sensors
Will see how it goes.
VStar650CL
Technical Expert
Like I said, efficiency codes are common with cheap aftermarket cats. Try the spacers on both banks, chances are that's the whole problem.
jsando2
I will try that first but I was looking a the upstream sensor and I got the wrong one for bank 2 installed
VStar650CL
Technical Expert
Well, wrong parts will pretty much always cause issues. Better switch it out. ;)
jsando2
So today I went underneath to check my O2 sensors and install the O2 Spacers. Well first the spacers are too long I need the short ones and theres not much space to work around. Also I noticed that the Catalytic converter on the lower side theres a gab and I dont see a gasket either, I tried to adjust them but I broke one bolt but it can be replaced no biggie. Im thinking that theres my problem that gap. Well i just bought short O2 sensor spacers and I will take it tomorrow to the shop to see if they can fix that lower side and tighten it up really good. Will see.
VStar650CL
Technical Expert
jsando2 wrote:
Tue Oct 26, 2021 7:42 pm
That's very likely. Even a tiny putt-putt exhaust leak at the converter can cause a P0420.
jsando2
I don’t see a gasket there, so you know what type of gasket goes there, I’ve been looking around but nothing let me know if you know which gasket is suppose to be there
VStar650CL
Technical Expert
They almost all use crush rings.
VStar650CL
Technical Expert
Just confirmed it, should be a crush ring on each one. P/n looks to be 20691-51E01, same on both cats.
jsando2
Ok so took it to the shop and yes it is the metal oring gasket. They took care of my leak but they said they can’t put the o2 sensor extension because there’s no space for it. I reset the engine light and so far so good and it feels way better let me cross my fingers I hope it stays like that but I’m not too sure about that oh well next will be to buy another catalytic converter but a good one
VStar650CL
Technical Expert
They sell right-angle spacers, in my experience that's what most Nissans need. There isn't usually a whole lot of room between the O2's and the floor of the car. That's what's on my '04 Altie, and you probably need the same thing.
jsando2
Well tonight guess who came to visit! Yup Mr. P0420. It’s so frustrating aferre spending so much money I’m still in square one. I will try those L spacers to see if it works. My cars are under a spell I’m telling you.
VStar650CL
Technical Expert
You might want to check out this thread if the spacer doesn't work, it has some good pics and a lot of detail I didn't go into here. You might have a wiring issue just like he seems to have, and some scanner work may help you identify it:
topic629985.html
jsando2
Thanks! he got that same issue still it never says how it ends, anyway i will go with the angle spacers and see how it goes.
VStar650CL
Technical Expert
He's still working on it like you are, follow on. :woot:
jsando2
Yeah I will try the spacers then I guess it will be a new and better catalyst because with my obd won’t tell me if is a sensor which one is or I just don’t know how to read it
VStar650CL
Technical Expert
The spacers usually work, but if they don't, it might be a better idea for you to get or borrow a better scanner. The choppy waveform that @Dedpul's scanner pulled up is what's pointing to a ground issue, and without the scan he could have thrown parts at the problem for months without solving anything.
VStar650CL
Technical Expert
By the way, Torque Pro is $4.95 in the Google Store and even a good ELM327 adaptor costs around $18. China-cheap ones are more like $8. So it doesn't cost a lot to have a good scanner right in your smartphone.
jsando2
So this combination of obd and app is better? Will it tell me for example which sensor is jacked up?
VStar650CL
Technical Expert
For an extra $2.49 Torque Pro will do realtime graphic plots similar to the ones in @Dedpul's thread, and it's a lot cheaper than a high-end scanner.
https://play.google.com/store/apps/deta ... n_US&gl=US
Return to “Murano Forum”
