Dark_Knight wrote: ↑Fri Feb 15, 2019 1:32 pm
Are you hearing screeching from your brakes? Even if you are, it might just be debris in between the pad and the rotor. If the pads aren't too worn down you should be fine.
No noise, just the dealer's service manager urging me to replace only the REAR brake pads and resurface the rotors for $350. He said something like if I wait too long and the rotors and pads are needed it would be almost $800 ... which is ridiculous.
The also insisted I do the AWD fluids for $250 since i have 44K miles, replacing the cabin filter for $125, replacing my aftermarket engine air filters with OEM, etc. I declined all of that.
