Upgrayedd »
https://forums.nicoclub.com/upgrayedd-u265068.html
Wed Dec 27, 2017 4:45 pm
Oddly enough, looks like I had multiple starting issues hit at once. The battery cable fixed the poor connection and "bad starter symptoms", hopefully that's all it was. But it started having a hard start issue immediately after, so soon that I thought I hadn't fixed it. It would crank over but take a long time and multiple tries before it started, and when it did it would stumble just a bit. Turns out the fuel pressure regulator and fuel pressure damper were both shot. I pulled the vacuum lines and there was fuel in both. Got new parts installed and it fired right up. Fingers crossed that it is fixed now.
Side note, the screws for the regulator are extremely soft, and most likely extremely stuck. I had to use vise grips to break them loose as a screwdriver will just strip out the head.
