Something as simple as changing interior bulbs to LEDs can fry a electronic or body control module (ECM/BCM). I believe it's happened to Ilya, I know I've done it and am pretty sure there are a couple of other fellas that it's happened to. I have learned to disconnect the battery when doing ANYTHING electrical in my car. Since then I've hard wired a radar detector to my rearview mirror, installed a fuse tap at the fuse box to power a separate 12v socket, and changed the color of the LEDs in my start button without any issues.
My problem was the same, so Infiniti tech tried:Ilya wrote: ↑Sun Oct 22, 2017 8:29 pmInterior lights work when buttons are manually depressed but will NOT work with the door open and in 'auto' mode. If you have that symptom, you will not be able to fix this yourself. You will either need to learn to live with it or have an expensive repair done. Just replacing the BCM won't help you (I did that, did not fix my issue as I had dash harness that were melted/damaged from the short circuit).
I hate to be the bearer of bad news but I think you're in the same boat that I and a few others experienced. I'm not sure why Infiniti didn't properly fuse the lighting system on this car but your only way of fixing it is likely what I had to go through. Changing bulbs, fuses, etc. will not do much if anything. But it's worth a shot I suppose, can't get worse lol. Just unplug the battery this time lol (previous owner probably didn't).fernicus wrote: ↑Sat Oct 28, 2017 5:40 amso I'm now feeling as if this will be an intense expensive issue to fix. The ahem gent that sold me this car lied about it and of course amongst other things didnt' tell me about the lighting issues. I thought it was just a bulb in the trunk but was wrong. There is no power going through after testing the trunk with a circuit tester and all the cabin lights work except for the lights when opening the door ie courtesy or when using key fob to open door. The lighter itself was an issue until I changed the fuse and now when I depress the lighter, it pops up immediately. I'm wondering if suggested here I should try testing each fuse but seems that won't work seeing as cabin lights still work perfectly. Damn....... bringing it to mechanic next week. I can live with these things but still nice to have. I even ordered leds for the car online from ebay and they don't fit the damn car! Do you guys think swapping out and testing all fuses will hold some hope?
I think that is what the FSM is trying to describe with the "READ" and "WRITE CONFIGURATION" steps with the Consult device prior to replacing the BCM. You need to store all your model's particular info prior to the swap so that you can reprogram all that data back into the new, swapped out BCM. So you need a Consult device or other OBD2 diagnostic/programmer device that can program ECUs and other modules (I have been looking at devices other than the Consult to see if there are cheaper alternatives - Autel Maxisys Pro MS908P, looks promising but it is over 2 grand and I'm not sure if it can reprogram a Nissan/Infiniti BCM
