Something I discussed earlier and deemed necessary. So now I did it, an aux fan since I had problems in extreme conditions in both traffic and on steep, slow 4WD grades. Since I'm a BMW guy it came out of some BMW, though I can't recall which one, probably E32 or E34. It's a tight fit behind the hood latch support, but it does have some room. I used 1/4" fuel line, split on the back of the frame, glued on with polyurethane caulking to prevent abrasion on the condenser, even though I don't think it's actually contacting it anywhere. Since it was a 2 speed fan which normally used low for A/C and high for high temp, I did the same installing a fan controller. Pulled power off a terminal in the fusebox marked of all things Aux fan, with a fuse inline withing an inch or so.
Before
The fan installed
The fan running
Controls weren't as simple as they could be since I elected to use low speed for A/C operation and high speed off a fan controller. But it works.
