Sorry to hear about that John! I'm sure you'll get it worked out in due time.John Dixon wrote:Developed a bit of an oil leak a few weeks back so decided to investigate when I had some spare time. Was a bit alarmed to find a hole punced in the top of the rocker cover!!To cut a long story short, it looks like if you re-grind the cams massively like mine were and reduce the base circle down a lot then you're going to have to compensate by fitting longer valves or the rocker arms can fall off like 8 of mine did (sure the 9k rpm didn't help) No serious damage fortunately but I could have done without it to say the least!New cams/longer valves on order soon and get it fixed once I move house.Oh, also, iskey datsun 1200 valvesprings apparently work perfectly in the VH45 and give abotu 90ibs on the seat.
Anyone got a spare set of 92 rocker covers?!
Dave's superstock revs out to 9000rpm on a regular basis and handles it fine on the stock HLAs!gs14racer wrote:but jared that problem goes away on SRs with solid lifters and properly shimmed valves. Ive seen countless motors with rocker arm stoppers spit them at 8000rpm, the key here is maintaining proper rocker to cam clearance, and the hydraulics will always fail at that kind of rpm.
John you could probably convert all of your lifters to solid the way we do sr20 ones and shim them internally if the clearance isnt too great because of the reduction in base circle that is, much much cheaper then getting new cams and valves and 10X better in the end.
That might be an attribute of the HLA profile versus the SLA profile...Mettler wrote:Dave's superstock revs out to 9000rpm on a regular basis and handles it fine on the stock HLAs!
No, because at least one inlet on each cyl was opening it ran OK and compression / leakage tests were all perfect. Does explain the low dyno though!!!XJared wrote:If the rocker was already out, did you not notice the misfire before the oil leak?
~2k NZD for the cams and 32 valves. Not too bad really!Aus450zx wrote:whats the ballpark for those?
Any more information about this. Does his sell cams.Mettler wrote:Dave's superstock revs out to 9000rpm on a regular basis and handles it fine on the stock HLAs!
Same for this. I tried searching. I come up with information but nothing to contact. Not in the market right now. But for future reference. Converted to US currency thats about $1500 (then plus shipping and whatnot ) which isnt to bad really. Also do you have to convert over to SLA or stay HLA. Sorry for all the newbish questions.John Dixon wrote:All parts on order. Hopefully be back on the road in a few months after I move house and stuff
