Olderthanme wrote:I was thinking about cam grinding and then looked at the VH45 valvetrain today...
Just looking at the VH valvetrain... How would I compensate for altered valvetrain geometry if the base circles on the cams was changed more than a little bit?Can the rollers in the rocker arms be replaced by rollers with a larger diameter? Are there lash pads under the tips of teh arm right at the top of the valve?
Thanks guys!Dan
If you change the roller diameter, you will change the duration of the cam lobe. Imagine using a larger roller, and imagine it's sitting somewhere on the base circle of the cam lobe. As the cam rotates under the roller, and the opening ramp approaches the roller, the larger roller will contact the opening ramp just a little bit earlier than the smaller roller would have. The effect will be largest when the pressure angle is greatest, i.e. along the middle of each side of the lobe.
We started grinding cams in 1970, and now we are the leading cam grinding company for industrial engines.
We have software that will convert profiles based on the size of the follower, so it is certainly possible to take the roller size into account and grind the appropriate cam profile to use a larger diameter roller.
ClayKams, Inc. - cam grinding for industrial engines
