Seems like an isolated incident though, and I question it a little.themadscientist wrote:SSAC manifold at work zerothread?id=131371
Did you purchase a manufactured mani, or did you have one made locally?teddy wrote:well i used to have a bottom mount ss mani and I had no problems with it at all. Hitting full boost at 4grand is no problem for me. Full boost at 5 is too much though. 400whp is my long term goal I'm shooting for, I know I'm not going to get it immediately. But I have been poking around on honda-tech lately due to their massive amount of info on turbos and I've seen quite a few Gs-r's running a hybrid t3 putting out around the 350's. What would be a more reasonable turbo then without going to a ball bearing setup. I refuse to use it due to my last experience. I want to be able to rebuild if something happens. Should I upgrade to a t3/60-1, or maybe a Precision turbo of some kind, say the sc34.
Thanks for all the feedback so far.
wrong person ryan... you're thinking of KaZ!float_6969 wrote:Man, I stil wish that you would have been able to finish the CA-Z32 project.
fallen180sx wrote:hey ca19.. when you flipped the mani over.. howd you hook up your downpipe?
exactly, i didnt jsut flip it over, it wasnt that easy, teh bolts wouldnt line up, i had to cut it off the runners off teh flange and flip it over, and it was a copy i had made, but hold them together and the bends were pretty much the same, and the runners were ~11" IIRC.. i did use a t3 flange,NeedCAforS13 wrote:he didn't exactly flip over the manifold... they put a t3 flange on a manifold that was designed like an ssauto manifold, but upside down. I think he brought the pictures of an ssauto manifold to a shop for them to look at.
Sean
what's wrong with it? that seemed like such a nice set up!CA19DET wrote:honestly if my trust manifold gives me any more beans
Did it help with the spool up, or widen the powerband??? About how much did it help (rough estimate)? and did it move the turbo placement alot?teddy wrote:I purchased the SSauto t28 mani from their site. No fitment problems and I actually used an sr turbo outlet and sr downpipe and had no problems with that either. the downpipe was about 3" away from the frame rail.
