I got the part from a junkyard and fixed it. I figured out what caused it to break. 2 plastic washers go to each side of this part and they made the joint VERY tight. Hydrolic arm pushes up, but this part couldn't rotate easily. I wasn't able to install it back to original condition at all. I sanded down a couple of washers and was able to finish the job. I lubed up the joint as well. Thanks for the replies and PMs!!
