to those who has arp headstuds
dvd
is it a must to use a snap on deep well 13mm 12point socket? Apparently the one that i purchased(35shipped grrr) was lost becuase my brother probably knocked it down and i dont know i'm jsut angry about the whole thing. Has anyone used the craftsmen sockets and was successful? thanks.
float_6969
My craftsman wouldn't work. I went and bought a cheap Ampro one from Advance auto and ground it down.
And I thought it was a 12pt, deepwell, 1/2"???
dvd
float_6969 wrote:My craftsman wouldn't work. I went and bought a cheap Ampro one from Advance auto and ground it down.
what did you grind it down with? a dremeL?
tyrannix
Car: go big or go home
i used one from napa it was around $7 and used a table grinder to make it thinner
a little too thin
i got all the inner nuts torqued to 76, then the outer 4 were on the last round and i heard a crack... not the snap that means the torque wrench saying "hey, youre all good now" but a crack, like teh ground down socket saying "hey ****tard, you ground off too much and made me too weak to handle 10x76 ft-lb work
the moral of the story: grind a little bit at a time off all sides until it fits... dont do too much, or youll be stuck with a half-done job until you get another socket
Nowhere
Car: Suzuki x-90, samurai
float_6969 wrote:And I thought it was a 12pt, deepwell, 1/2"???
1/2 inch = 12.7mm... It'd woooooooooooooooooooork, the exact socket would be best under HIGH torque.
