Tires for 1995 Nissan Maxima SE
crazyboy3012
Car: 2003 Infiniti G35 Sedan
Hello,
What is the difference between P205/65/R15 94T and 94S?
My car currently has the 94 T and i am finding good deal online for 2 X 94S
(by the way i just need to replace both the rear tires)
Is it ok to drive with the forward tires being 94T with the rear tires being 94S?
Thanks in advance
tigersharkdude
Car: 1999 Nissan Maxima
check out http://www.tirerack.com The S and T are speed ratings. S-112mph T-118mph The 94 and 95 before the S and T are load index ratings(meaning how much weight the tires can hold. 94-1477lbs 95-1521lbs
IMPO-I would go with the cheaper tires, unless you race your car "at the track"or autocross.
marlin29311
Car: 2008 Infiniti G35x
I wouldn't always go with the cheapest - even driving around town with crappy tires is not a good idea, especially when wet.
Post up a few tires you are looking at and then people can help you make a decision
crazyboy3012
Basically i looked at this website
http://www.bestusedtires.com/
for p205/65/R15 and i got some good deals for brand new tires as well as tires with 60-70% thread life.
Now most tires are available only as a single item i.e. i cannot buy a set of 2 or 4.
Is mixing and matching ok if all 4 tires are p205/65/R15 94 (T/V/S)
Further, if i look at reviews i am unable to decide on which tire might be a decent one for regular city driving.
i live in north seattle and drive 2 miles to work each way..lol
Thanks in advance
tigersharkdude
marlin29311 wrote:I wouldn't always go with the cheapest - even driving around town with crappy tires is not a good idea, especially when wet.
wrote that wrong. if he is looking at the same tire and the S is cheaper than the T, get the S
tigersharkdude
checked out the site. see if you can get the falken ze-512 or 912. good tires for good price
crazyboy3012
Thanks !!!
One more thing...
is 205/65/R15 92H the OEM spec on a 1995 Maxima or is it
215/60/R15 93H?
I got a used 1995 nissan maxima and it did not have an owners manual. I downloaded a 1996 owners manual online and it lists both the above tires as conventional tires for a 1996 Nissan Maxima.
I am a little confused if i should go for the 205/65/R15 92H or 215/60/R15 93H
Thanks in advance
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
205 if you have a gle or gxe and 215 if se models. depends on your rims though so make sure which ones you have - honeycomb, steel = gle, gxe and saw blades = se.
marlin29311
tigersharkdude wrote:wrote that wrong. if he is looking at the same tire and the S is cheaper than the T, get the S
I was going more for the "don't buy the cheapest tire because it costs less" - that can put you in a bad spot sometimes. You always want to get a decent tire that gets good traction, but I agree with your speed rating point on the same tire.
I would not buy used tires - that has bad news writtten all over it - you don't know where they've been, what has happened to them, if they've ever been repaired, etc...too risky IMO.
You can always go to http://www.tirerack.com to find the best fitting tires for your car
crazyboy3012
Thanks a lot guys!!!!
Appreciate everyones feedack.
jackie
Here is the portal, where you can find and buy or sell http://www.tradekey.com/ks-used-tires/
