Yes, I hate it too and that's why I asked here. So, this foam gives natural look? Is there any spray on product that gives natural look? If not, I'll try this.dusred wrote:I HATE the shinny look that just the spray on Armor All leaves; in my opinion it looks like you just sprayed WD 40 on the tire.
That sucks. I've used a couple of tire cleaning products and they look good first, but become brown over the time.marlin29311 wrote:don't use any tire dressings - the vast majority of them break the rubber down and can lead to premature wear on your sidewalls. The best thing to do is when you wash your car, simply take the soap and clean them like that. Most tire manufacturers put a protective coat on the sidewalls at the factory to help them keep the black look for a long time - the dressings only break this down, giving you that "brown" look.
This s very true, and one thing is that most are very slippery and could cause you to lose traction. Though I have never had a set of tires more then 7 months so thats not a huge deal to me. i just use simple green and a stiff brush to clean my tires.marlin29311 wrote:don't use any tire dressings - the vast majority of them break the rubber down and can lead to premature wear on your sidewalls. The best thing to do is when you wash your car, simply take the soap and clean them like that. Most tire manufacturers put a protective coat on the sidewalls at the factory to help them keep the black look for a long time - the dressings only break this down, giving you that "brown" look.
