No, thanks. I'd much rather be slightly slow than slightly fast.I have enough trouble holding down my speed as it is!guigow wrote:Try 205/60 R15. I changed the stock tire to this after get my car in the dealer.
I'm swapping out my stock 185 /65/15 junk Conti's as soon as I can find some alloy rims. Gonna put the 205/60/15 tire on them. It's not about speed. It's all about stability and road handling w/the 205's. On the Miata site you'll see side by side the difference. Mileage might drop a bit but I rather have a better handling car.Elmojo wrote:
EV: Are you sure about that model?Check out the reviews here: http://www.1010tires.com/tirer....htmlAnd some customer grading here: http://www.tirerack.com/tires/...+Plus
They don't look too good to me.Just wondering if we're talking about the same tire?
I'm positive about the model. They were the OE tire on my Optima. I have to disagree with bucksnort's experience. My Michelins were flawless, never had any sort of balance, tread, or belt problems.Elmojo wrote:They don't look too good to me.Just wondering if we're talking about the same tire?
Nah, the name is misleading. We have NO snow and almost NO hills! LOLI hear you about the advantages of the 205 over the 195, but speedo accuracy is way more important to me than it should be. The V is the first car I've ever owned with a spot-on speedo. The gauge and my GPS match within .3-.5 mph from 10 to 95, and I'm just not happy about giving that up. However, I might still go with the 205's as you suggest. I'll have to think on it some more. Did you have any trouble with the tire fitting the rim width? Also, with the extra width, does the tire always look like it's a bit low on air? I oversized the tires on my Avalon and have that issue. It's no biggie, just a little annoying visually.bucksnort wrote: I see you live in Snow Hill so sumptin to think about.
Elmojo wrote:I'm thinking of going with a slightly larger size to increase grip, but I don't want to throw off the speedo too much.
I really don't understand you... The variation of my suggested tires are less than your suggestion for 195/60. 0,9% is absolutely nothing. And if you consider that original speedometer has 0,4% of error marge than this (62mph is 59mph on the speedometer), i dont see any problem.Elmojo wrote:No, thanks. I'd much rather be slightly slow than slightly fast.I have enough trouble holding down my speed as it is!
Picked up these babys yesterday from craigslist. Were off a 2002 Infiniti G20 Touring model. I think the chrome is pretty rare. Tires are Pirelli P400 205/60/15 with 80%+ tread left. Alls I have to do is pickup some chrome lugs and the wifeys Versa has some new blingguigow wrote:Try 205/60 R15. I changed the stock tire to this after get my car in the dealer.
PS.: I used the same site. miata.
Some tires give better MPG than others. I got a set of 4 Blizzaks 205/60/15's for $100 on CL that'll go on the stock steelies for winter driving. Can't wait to feel the difference with the more stable and wider tyres. The stock Conti's are a joke. They'll go to CL or on the kids car when they need some rubber for 10K miles. The tires were the only weak link on the V when I bought it. I knew this and off they go.XterraVersa wrote:I got Goodyear Assurance TripleTred tires about a month ago. 195/60 R15 (They claim 80k miles)
Don't know if it was the tires or fuel blending, but my mpg is up about 2 mpg this month to ~35 mpg.
Let me see if I can clarify:I understand that the % variation between the stock tire size and the 205s you suggest is less than with the 195s I specified.The issue is not so much the amount of variation as the direction.As I stated in an earlier post, I'd much rather the speedo show that I'm traveling faster than actual rather than slower than actual.For example, say I'm really traveling 60mpg per GPS.With the 195s, the speedo will report ~59.5With the 205s, the speedo will report ~60.5I know that's only 1 mph difference, but I read the speedo down to ~0.5 mph, and in my area, 1 mph can be the difference between getting a ticket and not.Overall, I'd rather err on the side of caution, which is slower.guigow wrote:I really don't understand you... The variation of my suggested tires are less than your suggestion for 195/60. 0,9% is absolutely nothing. And if you consider that original speedometer has 0,4% of error marge than this (62mph is 59mph on the speedometer), i dont see any problem. If you want grip, go at least to 205.
You must have some real prick Gestapos down there. Otherwise it's pretty anal to worry about being off .5-1 mph on your speedo. I better watch it when I come thru NC this summer on the way to the Banks.Elmojo wrote:
However, I'm prepared to live with the speedo error if you think the handling/grip difference between the 195 and 205 is noticeable.Thoughts?
You said it, not me!Of course, they're not all overzealous teabaggers, but we have enough of them in my neighborhood to make life above 60mph a real hassle.It doesn't help that I tend to drive a lot of back roads....nevermind.bucksnort wrote:You must have some real prick Gestapos down there. Otherwise it's pretty anal to worry about being off .5-1 mph on your speedo. I better watch it when I come thru NC this summer on the way to the Banks.
Ummm, speak for yourself! LOLsrellim234 wrote:...but it's not like our family Versa is ever going to go over 80 mph anyway.
Any thoughts or experience with the Pirellis?
