Tire Pressure
amr40509
Quick note -- just because I have a few min.
It sounds like a lot of you are first time new car owners...but even for the ones that are not...
Check you tire pressure. It seems like from the dealer it is always WAY too high. Every new car I've had has come w/ over 40psi in the tires. The wife's Rogue had 45-46psi. Drop it down to 33-37psi.
jaywhiz21
Car: 2008 Nissan Rogue Gotham Gray SL AWD
My tires were overinflated at delivery also -- up to 6 pounds each.
Dropped 'em down to 33.-Jimmy
nissantech06
Car: 2007 Nissan Sentra S 2.0
amr40509 wrote:Quick note -- just because I have a few min.
We set our pressures on the cars at the time we do the PDI...some dealerships don't do it, but if you look in the booklet you get when you buy the car, someone should have checked off "checked tire pressure and set to spec".
worldbikr
Car: na
mine were 46 also. wow. I thought the ride was a bit bumpy but not being familiar with new cars lately I thought the suspension was a little stiff.
Return to “Rogue Forum”
