_b.jaye_ wrote:just picked up a set of anniversary style 5 spoke wheels (not sure what year car they came off of) and im not seein the tire pressures register on the gage... was readin around on here and it looks like some of the newer cars only have a low pressure indicator. can anyone here confirm what i might have going on & more importantly, know if i can swap the sensors from my old wheels into the 5 spoke ones?
I take it that you have physically seen the TPS on your anniv. wheels?If so & they are not working you can take it to your dealer to be re-programmed to your car.
On th other hand, you can remove your old sensers & if you knew exactly which wheel they came off of...no need to be re-programmed...just make the switch. Example, right front wheel TPS, goes on the right front wheel only!
