Tire Pressure Light! Help!
Nissan 350z / Nissan 370z general community discussion forum
CluberZ33
Ok So this mornin I get into my Z and see that the Tire pressure monitoring service light is on. Apparently in reference to the owners manual It comes one when the tire pressure needs to be slightly adjusted. But I got one question... Anybody ever have the TPMS light come on also? If so, How did you reset it? I checked all four of my tires and nothing is wrong with any of them. I called in to the dealership this morn, and the tech said there is either sumthing in my tire, or that the TPMS light just needs to be reset. If anybody has any answers to this problem, please let me know!
pc1212
Yeah your tire pressure is probably a little low. Check the recommended tire pressure and put some air in until you reach the desired psi.
RED ST
Car: 91 nissan 240sx coupe
take it for them to reset.. and check your pressure
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
step one, check your tire pressures! if one is low then the lite is doing it's job by alerting you, if they are all at recomended pressure then try resetting it, there si a little button, on the console of the Z33 IIRC (might also be on the dash), looks like a "U" with an "!" in the middle of it, press and hold that buttone for a few seconds (the owners manual should detail this process) if it won't reset then you have a bad sender, and the dealer should replace ti on your 08 for free
CluberZ33
Yeh turns out my light only needed to be reset. Thanks for the advice ! And turns out there is nothing wrong with my Bridgestone potenzas.
R350Zz33
Car: 2008 350z enthusiast
those tiers suck thats whats wrong with them
Burtonboarder950
Car: 2005 350z touring
R350Zz33 wrote:those tiers suck thats whats wrong with them
those are amazing tires...i think nissan knows what is best for their cars
CluberZ33
Yeah they do suck...Thats why I have 18 inch Works on the way with Toyo proxes
Retired Chief
I bought my ’08 350Z last night. I was driving home and as I was about 20 miles from the Nissan dealership, the low tire pressure light came on and stayed on. I checked the pressure when I got home and all 4 tires were spot on at 35psi. After work today, I took the car back to the dealership about 45 minutes before the service department closed. They checked the pressure and reset the light. As I was driving home, again about 20 miles from the dealership, the light came on again. I would have gone back but the service department was already closed. So, I guess I’ll be going back again tomorrow.
My wife bought an Altima Coupe 3.5 a couple of months ago and it has been nothing but one problem after another. My Z is only the second Nissan we’ve owned and it appears to be off to the same start as my wife’s car. So far, I’m not impressed with Nissan’s quality control.
evildky
06 Nissan 350Z GT
the last new nissan I bought was a 99 frontier and it was trouble free needing only scheduled maintenance and brakes and one hose clamp in the 80k I owned it, my )04 silverado has had the speedometer, transfer case control module, transfer case control switch, transfer case encoder motor, stereo all have had to be replaced, not sure if it's newer vehicles or just a few bad ones slipping through
Return to “350z / 370z Discussion”
